About Mapserver Native Oracle support and OGR Oracle support
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Mon Oct 24 06:59:18 EDT 2005
Hi Robert,
what do you mean by this exactly?
Using the native Oracle spatial connector you can also retrieve other columns than the geometry column.
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Robert oude Lohuis <oudelohuisr at VERTIS.NL> 24-10-2005 12:50 >>>
True, but there is a difference:
The native support does not have the capability to get administrative data
from the database, but delivers only the geometry data. OGR does have
support for queries which deliver data of other database-columns other than
But, as Bart already mentioned, this comes with a price. The performance
decreased in our case with a factor 2.
greetz,
Robert.
On Mon, 24 Oct 2005 12:05:25 +0200, Bart van den Eijnden
<BEN at SYNCERA-ITSOLUTIONS.NL> wrote:
>I think the Mapserver native would be the preferred way. It should have the
best performance, and it has the same features as the OGR one. Note that the
OGR OCI driver was mostly developed for writing data and not so much for
reading (so it might not be completely optimized for that).
>Best regards,
>Bart
>Postbus 270
>2600 AG DELFT
>>>> Jukka Sirviö <Jukka.Sirvio at ARBONAUT.COM> 24-10-2005 10:24 >>>
>Hello!
>Does anyone have a suggestion which is the preferred way for getting the
>spatial data from Oracle? Is it Mapserver Native support or is it through
>OGR / gdal? What are the drawbacks / benefits for both of these? I already
>know that if I use ogr approach I have to compile gdal and then compile
>mapserver for this version of gdal.
>I quess that Mapserver native approach is more widely used?
>Yours:
>Jukka
