wmsclient
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Mon Oct 24 10:36:08 EDT 2005
Can you check the source of your red cross image (right mouse button, properties, and then copy the URL) and put the URL into a new browser window? That might give you more information.
Otherwise check the following:
1) can you create a GetMap request to the WMS service in a URL and get a working image back?
2) try some debugging on Mapserver, see eg:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?DebuggingMapserver
3) do you need a http proxy to connect to outdoor services?
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Roland Forster <rf123 at GMX.NET> 24-10-2005 16:17:37 >>>
Hello,
I try do set up a cascading wmsserver including several wms services but
get no result.
I use the mapbender frontend to load the maps.
There is no error message. Just an empty screen with a red cross in it.
I'm running mapserver 4.6.1.
Is there something wrong with my mapfile?
Thank you in advance,
Roland
Here is my mapfile:
MAP
NAME "test"
STATUS ON
DEBUG ON
#EXTENT 3446461 5811888 3511872 5880234
UNITS METERS
IMAGECOLOR 255 255 255
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE PC256
EXTENSION "png"
TRANSPARENT ON
END
WEB
# WMS-Support
METADATA
"wms_title" "test"
"wms_onlineresource" "http://<ip>/cgi-bin/mapserv.sh?
map=../demo/1_kaskade_test_wms.map"
"wms_srs" "EPSG:31463"
END
IMAGEPATH "/www/html/tmp/"
IMAGEURL "/tmp/"
END
PROJECTION
"init=epsg:31463"
END
LAYER
NAME "intevation"
TYPE RASTER
STATUS OFF
CONNECTION "http://demo.intevation.de/cgi/frida-wms?"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "epsg:31463"
"wms_name" "gewaesser"
"wms_server_version" "1.1.1"
"wms_format" "image/png"
END
END
END # Map File
