PostGIS multiple table query
Edward Nuttall
ewnuttall at QINETIQ.COM
Tue Oct 25 11:11:55 EDT 2005
Dear all,
I am trying to get a PostGIS Layer working, the following layer works fine:
LAYER
NAME "my_layer"
TYPE POINT
STATUS ON
CONNECTIONTYPE POSTGIS
CONNECTION "dbname=my_db user=me host=localhost port=5432"
DATA "location from (select cars.location, cars.date from
cars) as myquery using unique location using srid = -1"
TEMPLATE "/home/qgis/mariss/image_info.html"
CLASS
NAME "My Layer"
OUTLINECOLOR 0 0 0
COLOR 220 220 0
SIZE 7
SYMBOL "circle"
END
PROJECTION
"+proj=latlong"
END
METADATA
WMS_TIMEEXTENT "2005-02-05/2009-10-01"
WMS_TIMEITEM "date"
END
END
However, when I extend the Query to included another table, as shown below:
LAYER
NAME "my_layer"
TYPE POINT
STATUS ON
cars, users where cars.id = users.id) as myquery using unique location
using srid = -1"
CLASS
NAME "My Layer"
OUTLINECOLOR 0 0 0
COLOR 220 220 0
SIZE 7
SYMBOL "circle"
END
PROJECTION
"+proj=latlong"
END
METADATA
WMS_TIMEITEM "date"
END
END
I get the following error:
"Postgresql reports the error as 'ERROR: find_srid() - couldnt find the
corresponding SRID - is the geometry registered in the GEOMETRY_COLUMNS
table?"
All geometry columns in all the tables are 'working' as layers in the
mapfile and have been registered in the GEOMETRY_COLUMNS table, also the
select query does return a result set. I can see there is some SRID error,
and this is where I get confused, when I've added my geometry columns I
have always used -1, indeed anywhere SRID pops up I have just used -1.
Any help would be much appreciated,
Thanks
Ed
