FW: [UMN_MAPSERVER-USERS] Upgrade Problems - Additional Info
    Yewondwossen Assefa
    assefa at DMSOLUTIONS.CA
    Wed Oct 26 11:53:37 PDT 2005
Tom,
  I just rechecked and the gdal zip file included in the distro is
gdal-1.3.1.zip which include gdal13.dll.
  Not sure what is going on.
later,
Kralidis,Tom [Burlington] wrote:
> Assefa,
> http://dl.maptools.org/dl/mapserver-4.6.1-win32-php5.0.5.zip still has
> an older gdal in there.  Can we get an updated distro with GDAL 1.3 and
> PHP 5.0.5 / MapServer 4.6.1?
> ..Tom
>>-----Original Message-----
>>From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
>>Sent: Wednesday, 26 October, 2005 14:31
>>To: Kralidis,Tom [Burlington]
>>Cc: MAPSERVER-USERS at LISTS.UMN.EDU
>>Subject: Re: [UMN_MAPSERVER-USERS] FW: [UMN_MAPSERVER-USERS]
>>Tom,
>>I have upgraded the php/mapscript download site with new windows
>>binaries (http://www.maptools.org/php_mapscript/).
>>Later,
>>>Everyone,
>>>Follow up to this thread.
>>>It seemed that an updated gdal fixed this issue.  The gdal
>>used with
>>>the distro Tim was using was 1.2.6.
>>>Having said this, where can one fetch a Win32 dist of
>>MapServer 4.6.1
>>>/ PHP 5.0.5 / GDAL 1.3.1 ?  I'm guessing this will be a hot
>>item (alot
>>>of my stakeholders share Tim's type of configuration and connection
>>>bindings).
>>>Thanks for Frank and Tim for their guidance and testing support.
>>>Cheers
>>>..Tom
>>>From: UMN MapServer Users List
>>[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
>>>On Behalf Of Kralidis,Tom [Burlington]
>>>Sent: Monday, 17 October, 2005 12:29
>>>To: MAPSERVER-USERS at LISTS.UMN.EDU
>>>Subject: Re: [UMN_MAPSERVER-USERS] Upgrade Problems -
>>Additional Info
>>>>On 10/17/05, Kralidis,Tom [Burlington]
>><Tom.Kralidis at ec.gc.ca> wrote:
>>>>>Is or has something happened to the way the .ovf or underlying OGR
>>>>>process handles precision of coordinates when doing
>>spatial filters?
>>>>Tom,
>>>>I haven't dug through the previous emails closely to see
>>what is going
>>>>on, but I thought I should answer this.
>>>>There has been a substantial improvement in the amount of precision
>>>>OGR maintains for WKT and GML encodings of geometries.  The changes
>>>>were applied a couple months ago.
>>>>They are definately in GDAL/OGR 1.3.1 and might be in 1.3.0.
>>>>OGR spatial filtering will also now use GEOS if built-in.  It is
>>>>possible that some "on the edge" situations would give different
>>>>results now compared to in the past.
>>>>I'm not sure if any of this relates to the problem you are seeing
>>>>though.
>>>Thanks for the info.  I don't think these instances are
>>using WKT/GML
>>>as input or output, if that's what you mean.  Basic .ovf
>>connection to
>>>provide WMS output.  Is there anything we can do on our end to help
>>>with this issue?  The problem is basically:
>>>ENVIRONMENT
>>>OS: Win32
>>>MapServer: 4.6.1 windows dist (non ms4w package from
>>>http://maptools.org/dl)
>>>Layer Data connection: OGR .ovf connection to M$ SQL Server 2000
>>>SCENARIO 1
>>>- invoke OGC:WMS GetMap request against said layer with coordinates
>>>formatted with 8 decimals
>>http://cabin.cciw.ca/cabin_ows.asp?version=1.1.1&service=WMS&request=G
>>>et
>>Map&layers=CABINPoints&styles=&bbox=-141.00000000,35.18749999,
>>-51.999999
>>>99,90.81250000&format=image/png&srs=EPSG:4326&width=500&height=300
>>>Result: works
>>>SCENARIO 2
>>>formatted with 9 decimals
>>>et
>>Map&layers=CABINPoints&styles=&bbox=-141.000000002,35.18749999
>>8,-51.9999
>>99997,90.812500001&format=image/png&srs=EPSG:4326&width=500&height=300
>>>Result: watch server timeout ensue
>>>NOTES
>>>- this does not exist when the layer data connection is a
>>shapefile,
>>>for example
>>>..Tom
>>Assefa Yewondwossen
>>Software Analyst
>>Email: assefa at dmsolutions.ca
>>http://www.dmsolutions.ca/
>>Phone: (613) 565-5056 (ext 14)
>>Fax:   (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax:   (613) 565-0925
More information about the MapServer-users
