Displaying chinese fonts inside GML
Taka Wong
taka_www at SINAMAN.COM
Thu Oct 27 22:39:17 EDT 2005
Hi
Does anyone having experience on displaying chinese fonts?
I am now using GML 2.12 as data source files, which containing a attribute
values in chinese/double byte fonts, once I call any layer image embedded
with a label of the chinese attribute, it had failed to show. Sometimes it
can show some meaningless character, and sometimes system claimed my GML
file is invalid.
I have found an article from OGR,
http://home.gdal.org/~warmerda/projects/wcts/imp_details.html
it stated the OGR XML/GML reader only support reading 8-bit XML file, XML
other than 8-bit would be fail in reading.
I wonder this problem has been solved. May I have some suggestions about
this problem?
Thank you very much.
Best Regards
Taka
