Dynamic Layer Creation Problem
    Stephen Woodbridge
    woodbri at SWOODBRIDGE.COM
    Sat Oct 29 18:25:25 PDT 2005
Hi Sean,
Thank you for the response. I tried adding that and still no joy. The
code looks like this now:
if ($line->{numpoints}) {
     warn "numpoints=$line->{numpoints}\n";
     my $lay = new mapscript::layerObj($map);
     $lay->{status} = 1;
     $lay->{type} = $mapscript::MS_LAYER_LINE;
     $lay->{name} = "tsp_route";
     my $class = new mapscript::classObj($lay);
     $class->{status} = 1;
     my $style = new mapscript::styleObj($class);
     $style->{color} = new mapscript::colorObj();
     $style->{color}->setRGB(255,0,0);
     $style->{size} = 1;
     $style->{symbol} = 0;
     warn "numclasses=$lay->{numclasses}\n";
     warn "numstyles=$class->{numstyles}\n";
     warn "color=" . $style->{color}->toHex() . "\n";
     my $shp = new mapscript::shapeObj($mapscript::MS_SHAPE_LINE);
     $shp->{classindex} = 0;
     $shp->add($line);
     $shp->setBounds();
     $shp->draw($map, $lay, $img);
Any other ideas, would be appreciated.
-Steve W.
Sean Gillies wrote:
> On Oct 29, 2005, at 6:54 PM, Stephen Woodbridge wrote:
>> Hi all,
>> I know this has been covered before but I haven't been able to find
>> anything that helps. I'm doing perl mapscript.
>>      warn "numpoints=$line->{numpoints}\n"; # reports 257
>>      $lay->{status} = 1;
>>      #$class->{status} = 1;   # doesn't help
>>      # what should the value for pen be? tried 0 and 1 to no luck
>>      $style->{color} = new mapscript::colorObj(255,0,0,1);
>>      #$style->{size} = 1;    # doesn't help
>>      #$style->{symbol} = 1;  # doesn't help
>>      warn "numclasses=$lay->{numclasses}\n"; # reports 1
>>      warn "numstyles=$class->{numstyles}\n"; # reports 1
>>      $shp->add($line);
>> This code is running but is not drawing the polyline, $line-> {numpoints}
>> = 257 points.
>> Yes, I know I can template this in the mapfile, but I would rather  not.
>> We have all these function in mapscript and it seems they should just
>> work if you do the logical thing like above.
>> -Steve W.
> Steve,
> You're neglecting to set the classindex attribute of your "shp"
> shapeObj. There are other problems in your code as well, but that's
> most likely the main one.
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://zcologia.com
More information about the MapServer-users
