Dynamic Layer Creation Problem
    Stephen Woodbridge
    woodbri at SWOODBRIDGE.COM
    Sat Oct 29 18:36:43 PDT 2005
Yeah! Got it to work:
if ($line->{numpoints}) {
     warn "numpoints=$line->{numpoints}\n";
     my $lay = new mapscript::layerObj($map);
     $lay->{status} = 1;
     $lay->{type} = $mapscript::MS_LAYER_LINE;
     $lay->{name} = "tsp_route";
     my $class = new mapscript::classObj($lay);
     $class->{status} = 1;
     my $style = new mapscript::styleObj($class);
     $style->{color} = new mapscript::colorObj();
     $style->{color}->setRGB(255,0,0);
     #$style->{size} = 1;
     #$style->{symbol} = 0;
     warn "numclasses=$lay->{numclasses}\n";
     warn "numstyles=$class->{numstyles}\n";
     warn "color=" . $style->{color}->toHex() . "\n";
     my $shp = new mapscript::shapeObj($mapscript::MS_SHAPE_LINE);
     $shp->{classindex} = 0;
     $shp->add($line);
     $shp->setBounds();
     #$shp->draw($map, $lay, $img);  #<<<<< seems this does not work!!!
     $lay->addFeature($shp);             #<<
     my $err = $lay->draw($map, $img);   #<< But this does
     warn "draw err=$err\n";             #<<
     my $errObj = new mapscript::errorObj();
     while ($errObj) {
         warn "$errObj->{code}:$errObj->{message}:$errObj->{routine}\n";
         $errObj = $errObj->next();
-Steve W.
Stephen Woodbridge wrote:
> Hi Sean,
> Thank you for the response. I tried adding that and still no joy. The
> code looks like this now:
>     $lay->{status} = 1;
>     $style->{size} = 1;
>     $shp->add($line);
>     $shp->setBounds();
> Any other ideas, would be appreciated.
> -Steve W.
> Sean Gillies wrote:
>> On Oct 29, 2005, at 6:54 PM, Stephen Woodbridge wrote:
>>> Hi all,
>>> I know this has been covered before but I haven't been able to find
>>> anything that helps. I'm doing perl mapscript.
>>>      warn "numpoints=$line->{numpoints}\n"; # reports 257
>>>      $lay->{status} = 1;
>>>      #$class->{status} = 1;   # doesn't help
>>>      # what should the value for pen be? tried 0 and 1 to no luck
>>>      $style->{color} = new mapscript::colorObj(255,0,0,1);
>>>      #$style->{size} = 1;    # doesn't help
>>>      #$style->{symbol} = 1;  # doesn't help
>>>      warn "numclasses=$lay->{numclasses}\n"; # reports 1
>>>      warn "numstyles=$class->{numstyles}\n"; # reports 1
>>>      $shp->add($line);
>>> This code is running but is not drawing the polyline, $line->
>>> {numpoints}
>>> = 257 points.
>>> Yes, I know I can template this in the mapfile, but I would rather  not.
>>> We have all these function in mapscript and it seems they should just
>>> work if you do the logical thing like above.
>>> -Steve W.
>> Steve,
>> You're neglecting to set the classindex attribute of your "shp"
>> shapeObj. There are other problems in your code as well, but that's
>> most likely the main one.
>> Sean
>> Sean Gillies
>> sgillies at frii dot com
>> http://zcologia.com
More information about the MapServer-users
