Authentication? {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Mon Oct 31 05:50:52 EST 2005
Hi Patric,
I havn't heard about any authentication modul in mapserver, I usually use
then apache auth module to add password protection to directories.
You have load the auth_module, add
LoadModule auth_module modules/mod_auth.so
to the httpd.conf file (propaply it is involved but in comment).
And add the protected directories to the httpd.conf to e.g.
<Directory full_path_to_your_dir>
AutName any_name
AuthType Basic
AuthUserFile file_created_htpasswd
Require user user_name_from_htpasswd_file
</Directory>
If you have several users, then you can add access right to groups.
See httpd.apache.org/docs/2.0/howto/auth.html
Bye
Zoltan
On Mon, 31 Oct 2005, Patrick Kosiol wrote:
> Hi,
> are there any user/password authentication integrations for mapserver
> implemented somewhere?
> Regards,
> Patrick
