Performance problem with drawing several layers using Postgis
Andre Karp
karp at MSP-DORTMUND.DE
Mon Oct 31 05:05:11 EST 2005
my problem sounds a bit obscure to me, but I couldn't figure it out on my
own neither searching the archive, so maybe someone of you can give me an
advice:
I want to use the Mapserver (cgi) to draw a map in which the polygons are
colored according to a datebase attribute (I think I have to store this
attribute in MySQL or Postgre since it's changed quite often through the
internet, several times a day). The user should be enabled to select one,
several or all layers out of a set of 15 Layers. Every layer contains the
same geometry: about 400 Polygons, not too complex; the corresponding
shp-file is about 1000 kB, and drawing the shapefile with mapserver
overlaying it 15 times takes less than a second.
First I tried accessing the attribute data which is stored in a
MySQL-Database via the OGR/ODBC driver, and performance was very weak (app.
10 sec.)(the join fields where indexed). Then I tried by moving my data
completly into a Postgis-based system (I also built a spatial index):
performace got better, but it still takes roughly 5 sec to get a map, just
drawing 15 Postgis-stored layers without any filtering or table joins and so
on. The application runs on a P3-800 Mhz with 512 MB RAM and Windows
2000/Apache System (well, not really fast, but should be sufficient since it
has to handle only one request a time?).
I would greatly appreciate if someone could give me an idea what could be
wrong with my application - thanks a lot in advance!
Here the relevant parts of my Mapfile (using OGR/ODBC):
LAYER
NAME "Layer1"
TYPE POLYGON
CONNECTIONTYPE OGR
CONNECTION "test.shp"
DATA "SELECT * FROM test LEFT JOIN 'ODBC:user at testdb'.tbl_reg_cat ON
test.ET_ID = tbl_reg_cat.et_id"
PROCESSING "CLOSE_CONNECTION=DEFER"
STATUS ON
and this using PostGIS:
LAYER
NAME "Layer1"
TYPE POLYGON
CONNECTIONTYPE postgis
CONNECTION "user=test1 password=pw1 dbname=test_pg host=localhost"
DATA "the_geom from test"
STATUS ON
CLASS
Regards,
Andre Karp
