MS WFS "Chaining"
Bart van den Eijnden bartvde at XS4ALL.NL
Mon Oct 31 23:24:42 PST 2005
this could be done I think. On your middle tier, you would have a
Mapserver WFS client layer, which you also expose as a WFS server layer
on the middle tier. The middle tier will then request the remote
Mapserver WFS.
So in summary, on your middle tier you would have a WFS Client layer in
your MAP file, and you would also expose your middle tier as a WFS
server using the appropriate wfs server metadata.
Does this make sense :-) ?
Best regards,
Bart
Chris Tweedie wrote:
>Morning list,
>A current work in progress requires extensive use of mapserver's WMS service
>chaining. My question is that as far as i can tell, there is no way to do a
>similar method using remote WFS services.
>To clarify, i am not after MS as a WFS Client (eg. render the WFS response as an
>image) but simply forward the response on to the client. For example,
>1. Client (WFS Request) --> Core Mapserver (Forward request) --> Remote
>Mapserver
>2. Remote Mapserver (GML Response) --> Core Mapserver (Forward request) -->
>Client
>I hope mapserver could be enabled as a sort of pseudo OWS "proxy" but I have had
>a look around without much success,
>Ideally, if there was a new meta tag such as
>"wfs_response_method"    "GML"
>or something similar attached to the layer, then this would suit my purpose
>exactly. Since the response is currently stored as a GML file in the ms_tmp
>directory anyway, it seems a simple manner of just forwarding on the request
>instead of rendering it using GDAL/OGR.
>Any feedback would be appreciated,
>Chris Tweedie
>This message was sent using IMP, the Internet Messaging Program.
More information about the MapServer-users mailing list
