Ka-map problems: problem attached as document
Delfos, Jacob
jacob.delfos at MAUNSELL.COM
Mon Apr 3 04:34:22 EDT 2006
Ben,
I notice you have no shapepath defined, and the path to your shapefile
is not a complete path. This *may* be an issue, but not likely the cause
of your problem.
It would really help if you could attach the output of your php log
(make sure you set up PHP to log to a file, see php.ini in c:\windows).
That tells us whether something goes wrong on the server. If nothing
relevant shows up, try to download firefix, because it has good
javascript debugging abilities. Select "tools->JavaScript Console", and
see what is happening there.
Please provide us with the output, and we will have a better idea. By
the way, I have CC'd this to the Ka-Map list, which I recommend you
subscribe to.
Regards,
Jacob
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Ben Crane
> Sent: 3 April 2006 16:25
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Ka-map problems: problem
> Hi,
> I have attached a word document that briefly explains
> the problem I'm having with ka-map within Mapserver. I
> have looked at everything I could find but I'm sure
> it's something simple I have overlooked.
> The attachment is a Word document (zipped) which
> contains the problem, the system I'm running and what
> solutions I have tried.
> I trust this is acceptable to all?
> Regards
> Ben Crane
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
