How to use and interpret DEBUG?
Bart van den Eijnden
bartvde at XS4ALL.NL
Mon Apr 3 07:38:24 EDT 2006
The log file is more like an access log file and not very useful for what
you want to do.
To use debugging info, make sure:
1) Mapserver is compiled with MSDEBUG (check mapserv -v)
2) Your CGI knows where to log debug info, for Apache use: SetEnv
MS_ERRORFILE "stderr" in the httpd.conf so that debug info gets into the
Apache error log, for IIS use system environment variable named
MS_ERRORFILE and restart server machine, you can also log to a file if you
make sure your webserver has write access to it
3) in the Apache error log the drawing times will be reported
Hope this helps.
Best regards,
Bart
> Hi,
> I got interested in comparing the performance of using tiled geotiffs with
> overviews v.s. JPEG 2000 images. So far I have set "DEBUG ON" in map
> object, named a logfile in the web object, made two layers from geotiffs
> and JPEG 2000s and set "DEBUG ON" for the both.
> Now when I send requests to Mapserver I get new lines to logfile, but I do
> not know where I should find the time that it takes to render the layer.
> Here is an splitted example of the lines I am getting to the log:
> Mon Apr 03 13:08:52 2006, #this is obviously date and time
> 2732, # no idea about what this is
> 1xx.xx.xx.xxx, # IP address of the requesting computer, I believe
> Tifspeedtest, # name defined in the mapfile
> 3, # no idea about this, but value seems to be always "3"
> 2539375.000000 7220000.000000 2545625.000000 7225000.000000, #
> extents of the request
> -1.000000 -1.000000, # no idea about these two either
> Geotiff , # names of the requested layers
> normal execution # the result
> Now I wonder if this is the way to do this, and if so, then what I should
> think about the numbers. I wonder also why I get two lines per request if
> I send "&mode=map&layers=Geotiff" request through browser, but nothing at
> all if I am sending WMS "GetMap"requests with the browser for the same
> layer, even if I do get the map.
> Might there be some good document about using debug available? Those I
> have found helped me this far but not any further.
> Regards,
> -Jukka-
