4.8 query results problem
Didrik Pinte
dpinte at ITAE.BE
Mon Apr 3 08:41:02 EDT 2006
Le lundi 03 avril 2006 à 09:33 +0200, Didrik Pinte a écrit :
> Hi,
> The following layer and template has been defined under a 4.4 server and
> works perfectly well. Using it on a 4.8 server, it does work when there
> is an empy resultset but it displays nothing when they are results.
> Does anybody know how to debug the problem ? The problem is really
> strange, i have nothing in the debug output ...
> Didrik
This seems not very interesting according to the answers ;-) BUT
it's clear there is a real problem.
I've created a very very simple example. One layer configured with some
points showing fine and querying fine on a 4.4 server
When there is a point selected in the QUERY mode, here is the outputed
html file (i've cutted it following the template used):
<!-- WEB HEADER START -->
<html>
<head>
<link rel="stylesheet" type="text/css"
href="../mapserver/css/main.css" />
<!-- WEB HEADER END -->
<!-- LAYER HEADER START-->
<title>Aperçu de cuve</title>
</head>
<body>
<!-- LAYER HEADER END-->
Content-type: text/html
<HTML>
<HEAD><TITLE>MapServer Message</TITLE></HEAD>
<!-- MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
DEBUG=MSDEBUG -->
<BODY BGCOLOR="#FFFFFF">
</BODY></HTML>
Why is the CLASS TEMPLATE not used, nor the LAYER FOOTER and WEB
FOOTER ?
I'm going on investigating the problem without some much ideas ... Does
somebody else have that kind of problem with Debian/Sid mapserver
(4.8.3-1) ?
Didrik
Name: not available
Desc: Ceci est une partie de message
=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060403/634ee2d6/attachment.bin
