4.8 query results problem
J. Parapar
listario at GMAIL.COM
Tue Apr 4 05:01:09 EDT 2006
Hi Didrik
I remember there has been some issues with the last realeases of
PostgreSQL related to the oid fields (they are not created by default
now). Probably this is not the case but taking a look at the
PostgreSQL log may help.
Best regards,
Jorge
2006/4/3, Didrik Pinte <dpinte at itae.be>:
> Le lundi 03 avril 2006 à 09:33 +0200, Didrik Pinte a écrit :
> > Hi,
> > The following layer and template has been defined under a 4.4 server and
> > works perfectly well. Using it on a 4.8 server, it does work when there
> > is an empy resultset but it displays nothing when they are results.
> > Does anybody know how to debug the problem ? The problem is really
> > strange, i have nothing in the debug output ...
> > Didrik
> This seems not very interesting according to the answers ;-) BUT
> it's clear there is a real problem.
> I've created a very very simple example. One layer configured with some
> points showing fine and querying fine on a 4.4 server
> When there is a point selected in the QUERY mode, here is the outputed
> html file (i've cutted it following the template used):
> <!-- WEB HEADER START -->
> <html>
> <head>
> <link rel="stylesheet" type="text/css"
> href="../mapserver/css/main.css" />
> <!-- WEB HEADER END -->
> <!-- LAYER HEADER START-->
> <title>Aperçu de cuve</title>
> </head>
> <body>
> <!-- LAYER HEADER END-->
> Content-type: text/html
> <HTML>
> <HEAD><TITLE>MapServer Message</TITLE></HEAD>
> <!-- MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS
> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> DEBUG=MSDEBUG -->
> <BODY BGCOLOR="#FFFFFF">
> </BODY></HTML>
> Why is the CLASS TEMPLATE not used, nor the LAYER FOOTER and WEB
> FOOTER ?
> I'm going on investigating the problem without some much ideas ... Does
> somebody else have that kind of problem with Debian/Sid mapserver
> (4.8.3-1) ?
> Didrik
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.2.2 (GNU/Linux)
> iD8DBQBEMRfd9Rlh4Zs4yBMRAqJVAKCQ6oHj0vqF+HOO2Ug0z1llGZTJPACgp+0v
> sF7vKsZ0sZGA6+yfNRpJ2gY=
> =5RdX
> -----END PGP SIGNATURE-----
