MySQL OGR VRT
Frank Warmerdam
warmerdam at POBOX.COM
Mon Apr 3 17:26:18 EDT 2006
Fawcett, David wrote:
> Any ideas?
David,
My stock concerns would be:
o Is there a permissions issue with the web user? Try the map
with shp2img. If it works there the problem is likely the user
environment of the web user.
o Are you really really really sure you are using the same GDAL
DLLs (or shared libraries) in both situations. You would be
surprised how easy it is to have multiple versions on your system
and not be using the one you think you are!
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
