Tiling shapefiles
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Apr 3 16:52:16 EDT 2006
Chip Taylor wrote:
> I am running Mapserver 4.6 on Windows using IIS. The data presently
> focuses on the United states. I have a single mapfile that contains the
> layers to be rendered. The majority of my data is in ESRI Shapefile
> format. Most of the data is in national datasets. However, some data
> is only available by state or county. For example, the hydro data is
> national but pipeline data is by state. How would I most efficiently
> organize the state data so that the mapserver can seamlessly display the
> data when the geo extents allow? Is there a tutorial somewhere on
> tiling shapefile data?
Chip,
You can organize it any way you want, for example by state, by layer, by
vendor, etc. The trick is to get all the files for a given layer into a
metafile that can be used to create the tileindex.
pipeline-meta.txt
al/pipeline.shp
ak/pipeline.shp
etc
-or-
pipeline/al.shp
pipeline/ak.shp
etc
then:
tile4ms pipeline-meta.txt pipeline-tile
shptree pipeline-tile
and you in your mapfile
TILEINDEX "pipeline-tile"
-Steve W
