ms4w 1.5 -> filled symbols bleed at edge of map
listuser HH
listuser at HERZSYS.DE
Tue Apr 4 03:04:09 EDT 2006
Hi Jeff,
I searched bugzilla and found this
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1719. I think this is
exactly my problem. If I should add something to this bug or the other
please let me know. I will try to make a test case if necessary.
The mail to this was
http://lists.umn.edu/cgi-bin/wa?A2=ind0603&L=mapserver-users&P=R41256&.
Best regards,
Norbert
Jeff McKenna wrote:
> Can you possibly report this in the MapServer bug report that you
> refer to (http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1725)?
> Mention your MapServer version (4.8.3) in it, and they will probably
> ask you for a simplified test case (data and mapfile).
> thanks.
> jeff
> listuser HH wrote:
>> Hi all,
>> one or two weeks ago there was a problem with a symbol that "bleeds".
>> I just saw the same effect in the ms4w 1.5 package. A filled ellipse
>> symbol with a line on the edge of the map.
>> Best regards
>> Norbert
