OGR and oracle (MS4W 1.5)
listuser HH
listuser at HERZSYS.DE
Tue Apr 4 04:33:44 EDT 2006
Frank Warmerdam wrote:
>>> listuser HH wrote:
>>>> Hi Frank,
>>>> thanks for the answer. You are right something in the connection is
>>>> failing. I used SrcLayer for the data source definition - when I
>>>> use SrcSQL with a "select * .." it works.
>>> Norbert,
>>> The datasource definition (OCI:...) should go in the SrcDataSource tag.
>>> The SrcLayer should contain the name of the table you wish to
>>> operate on.
>>> You might want to use ogrinfo against the datasource to ensure that you
>>> are using the right name for the layer (table) as it might contain
>>> prefixes.
>>> Best regards,
>> Hi again,
>> I tried it like that. When I used orginfo on the datasource only one
>> table was shown. This was the table which has sdo geometry.
>> Here is my .ovf content for the x/y data table:
>> <OGRVRTDataSource>
>> <OGRVRTLayer name="netzknoten">
>> <SrcDataSource>OCI:[..]</SrcDataSource>
>> <SrcLayer>strassennetz.tmp_vw_netzknoten</SrcLayer>
>> <GeometryType>wkbPoint</GeometryType>
>> <LayerSRS>EPSG:31467</LayerSRS>
>> <GeometryField encoding="PointFromColumns" x="KOORDINATE_X"
>> y="KOORDINATE_Y"/>
>> </OGRVRTLayer>
>> </OGRVRTDataSource>
>> This produced the TNS problem. After that I changed SrcLayer to
>> SrcSQL and added "select * from" and it worked.
> Norbert,
> Hmm, I have no idea why this would give you the TNS issue (assuming
> thee are no XML escaping issues). However, if
> isn't listed as a layer name when you do "ogrinfo OCI:[..]" then it won't
> be available for SrcLayer.
> If there are any spatial tables in Oracle, then the OCI driver will
> only treat
> spatial tables as layers. If there are none, I think all non-spatial
> tables
> will be treated as layer.
> I believe there is a way of encoding a specific list of tables to
> treat as
> layers in the datasource name. Check the OCI driver page. I only press
> on this issue because there are performance and "correctness" issues with
> using SrcSQL. So it should be avoided unless it is needed.
> Best regards,
Hi Frank,
thanks again for your help. I expected that is better to use SrcLayer. I
checked the driver page and I saw that I used ",table" when I tested but
it must be ":table". Now the SrcLayer works if I give the table with the
datasource.
Best regards
Norbert
