OGR and oracle (MS4W 1.5)
Frank Warmerdam
warmerdam at POBOX.COM
Mon Apr 3 13:14:36 EDT 2006
listuser HH wrote:
> Frank Warmerdam wrote:
>> listuser HH wrote:
>>> Hi Frank,
>>> thanks for the answer. You are right something in the connection is
>>> failing. I used SrcLayer for the data source definition - when I use
>>> SrcSQL with a "select * .." it works.
>> Norbert,
>> The datasource definition (OCI:...) should go in the SrcDataSource tag.
>> The SrcLayer should contain the name of the table you wish to operate on.
>> You might want to use ogrinfo against the datasource to ensure that you
>> are using the right name for the layer (table) as it might contain
>> prefixes.
>> Best regards,
> Hi again,
> I tried it like that. When I used orginfo on the datasource only one
> table was shown. This was the table which has sdo geometry.
> Here is my .ovf content for the x/y data table:
> <OGRVRTDataSource>
> <OGRVRTLayer name="netzknoten">
> <SrcDataSource>OCI:[..]</SrcDataSource>
> <SrcLayer>strassennetz.tmp_vw_netzknoten</SrcLayer>
> <GeometryType>wkbPoint</GeometryType>
> <LayerSRS>EPSG:31467</LayerSRS>
> <GeometryField encoding="PointFromColumns" x="KOORDINATE_X"
> y="KOORDINATE_Y"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> This produced the TNS problem. After that I changed SrcLayer to SrcSQL
> and added "select * from" and it worked.
Norbert,
Hmm, I have no idea why this would give you the TNS issue (assuming
thee are no XML escaping issues). However, if strassennetz.tmp_vw_netzknoten
isn't listed as a layer name when you do "ogrinfo OCI:[..]" then it won't
be available for SrcLayer.
If there are any spatial tables in Oracle, then the OCI driver will only treat
spatial tables as layers. If there are none, I think all non-spatial tables
will be treated as layer.
I believe there is a way of encoding a specific list of tables to treat as
layers in the datasource name. Check the OCI driver page. I only press
on this issue because there are performance and "correctness" issues with
using SrcSQL. So it should be avoided unless it is needed.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
