OGR and oracle (MS4W 1.5)
Frank Warmerdam
warmerdam at POBOX.COM
Mon Apr 3 12:29:07 EDT 2006
listuser HH wrote:
> Hi Frank,
> thanks for the answer. You are right something in the connection is
> failing. I used SrcLayer for the data source definition - when I use
> SrcSQL with a "select * .." it works.
Norbert,
The datasource definition (OCI:...) should go in the SrcDataSource tag.
The SrcLayer should contain the name of the table you wish to operate on.
You might want to use ogrinfo against the datasource to ensure that you
are using the right name for the layer (table) as it might contain
prefixes.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
