Transformations in php mapscript
Ben Madin
bmad0463 at MAIL.USYD.EDU.AU
Wed Apr 5 03:15:21 EDT 2006
G'day all,
I am looking at some php scripts which load php_proj.dll and then use
pj_init and pj_transform.
However, when I load the page I get this message
Warning: dl() [function.dl.html]: Unable to load dynamic library
'\ms4w\Apache\php\extensions\php_proj.dll' - The specified module
could not be found.
followed by :
Fatal error: Call to undefined function: pj_init()
which I assume I need before I get to pj_transform (it fails anyway)
As you can tell, I have installed ms4W which must be without question
the easiest Mapserver setup around, but it didn't include php_proj,
which I have obtained from elsewhere.
I have searched the lists, read all the proj documentation etc, but I
don't seem to be able to get the library to load (I assume it is
required to make the pj_ functions work?)
thank you
Ben
