ANGLE parameter
Frank Warmerdam
warmerdam at POBOX.COM
Wed Apr 5 22:45:37 EDT 2006
Blammo wrote:
> All,
> I'm trying to get a test going using the ANGLE map parameter but not
> having much success.
> I found a reference to a "non-GDAL" raster, (what the heck does that
> mean)
Bob,
MapServer supports reading rasters via means other than GDAL.
But there are a number of raster features which are only available
when operating on rasters read through GDAL.
I believe ANGLE support is one of those things that doesn't work
for non-GDAL rasters. BTW, with GDAL enabled I think essentially
all raster support is through GDAL so this isn't usually a big
issue.
> related to raster warping in the how-to for raster data. I
> suppose this relates somehow to my source data, but how.
> Hmm, just found the requirement for the Projection info to be present
> for each Layer and the Map. I'll try this out in the morning.
This certainly used to be a key requirement. I think I have been
trying to relax it in the related "nonsquare pixel" ability which
is closely related to how angles are implemented.
> Question, it says in the MAP file doc's that it doesn't work with
> MapServer CGI, can the ANGLE param be passed in via the request? I
> tried a couple of variations earlier today,
> map_test_angle=0 (no effect on rotation)
> map_test_angle=1 (blank image)
Hmm. It may be that I did not add support for setting ANGLE from
cgi variables. I never use this myself, and I'm pretty uncertain how
this is supposed to work in MapServer. But if doing the above caused
a blank image, it must be doing something!
> and the parameter seems to be heard by the MapServer but anything other
> than a value of "0" returns an empty image. This was before discovering
> the info about the projection info requirements however. So maybe it
> will work after all.
Right, please report back if things still don't work when you have projections
on your map and layers.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
