Map file test fail
listuser HH
listuser at HERZSYS.DE
Wed Apr 5 07:41:34 EDT 2006
Joaquim Pinto da Costa wrote:
>Hi
>As a new user in a new mapserver project I'm testing my map file with
>shp2img. The results weren't very encouraging.
>C:\php>shp2img -m "C:\Program Files\Apache Group\Apache2\htdocs\AlAtlas\map\AlAt
>msProcessProjection(): Projection library error. No such file or directory <br>
it seems that your system is missing the path to the proj lib. You
should set the environment variables PATH and PROJ_LIB.
Which package and versions did you install?
Regards
Norbert
