Map file test fail
Joaquim Pinto da Costa
jpintodacosta at GMAIL.COM
Wed Apr 5 10:59:31 EDT 2006
Norbert
Thanks a lot it was indeed the PROJ_LIB env var.
Now it works like a charm and I think that from now on projections
should work on my system. About to test that :-)
Joaquim
> Hi,
> it seems that your system is missing the path to the proj lib. You
> should set the environment variables PATH and PROJ_LIB.
> Which package and versions did you install?
> Regards
> Norbert
