resolution SVG
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Apr 5 11:32:58 EDT 2006
Hi There,
There is a parameter called FULL_RESOLUTION that lets you control if
all points of a feature are transformed into svg coordinates or If there
is a filtering done.
(http://mapserver.gis.umn.edu/docs/howto/svg-howto). Is this what you
are looking for ?
Later,
soares wrote:
> when outputing an SVG map format from mapserver, can i change it´s resolution
> dinamically?
> for example, i have a path with 30 points, when i zoom out i want that path
> with - points, of course, for all the paths in the map!
> i use mapfiles, so is there any parameter i´m not seeing?
> tkx
> View this message in context: http://www.nabble.com/resolution-SVG-t1396363.html#a3755487
> Sent from the Mapserver - User forum at Nabble.com.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
