WFS Filter
Sture Dingsøyr
candalt at ONLINE.NO
Wed Apr 5 12:16:50 EDT 2006
Hi again and thanx for answer..
I have tried this (in my mapfile, displaying an GIF image):
If i use a regular mapserver filter expression, my layer gets correctly filtered. E.g: FILTER ('[servicename]' = 'Camping')
But if i use a SQL WHERE clause e.g. like this: FILTER "servicename = 'Camping'" no records are shown in my map.
I read that when using OGR and FILTER you should include "WHERE" in the filter (http://ms.gis.umn.edu/docs/howto/ogr_howto), so i tried that also: FILTER "WHERE servicename = 'Camping'". This time all the records are shown in the map.
So i guess the WFS FILTER transelates the XML into a WHERE clause, but i get the same result as with the WFS FILTER.... All records are returned...the filter expression is not "used"...?
Is this "a bug" or is this a feature that will be implemented later in Mapserver?
As mentioned before...this problem is only with OGR layers..not SHAPE, POSTGIS...
Regards
Sture
The way things work is that the filter encoding is transformed into something suitable for each layer and the layer's filter element is set with it :
* For shape file, It will be a normal mapserver expression,
* for postgis, oracle and ogr, it will be transformed into an sql expression. For OGR It should result into something like WHERE
(Item_name='Item_Value')
Bug http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1292 has more details on this.
What you could try is to set manually a valid sql expression on you layer's filter and see if that works.
Later,
Sture Dingsøyr wrote:
> Hi all
> Been doing some testing with Mapserver WFS and FILTER.
> When the Mapserver layer is getting its data from e.g. SHAPE, POSTGRESQL the WFS FILTER functions seem to work fine. I can filter data by using both BBOX or e.g. a PropertyIsLike query.
> But...i was now testing the FILTER functions on a layer where the data is from a MS SQL server (point layer). I am fetching my data via OGR. Mapserver renders the layer just fine, i can use WFS BBOX FILTER, but when i try a WMS FILTER using e.g. WFS PropertyIsLike query, Mapserver returns all records in the layer. Nothing gets filtered...
> Should not Mapserver (via WFS) filter data in the same way regardless
> of how the data is fetched...that is e.g. via SHAPE, POSTGRESQL, OGR
> etc
> Regards
> Sture
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
