WFS Filter
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Apr 5 11:21:24 EDT 2006
The way things work is that the filter encoding is transformed into
something suitable for each layer and the layer's filter element is set
with it :
* For shape file, It will be a normal mapserver expression,
* for postgis, oracle and ogr, it will be transformed into an sql
expression. For OGR It should result into something like WHERE
(Item_name='Item_Value')
Bug http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1292 has more
details on this.
What you could try is to set manually a valid sql expression on you
layer's filter and see if that works.
Later,
Sture Dingsøyr wrote:
> Hi all
> Been doing some testing with Mapserver WFS and FILTER.
> When the Mapserver layer is getting its data from e.g. SHAPE, POSTGRESQL the WFS FILTER functions seem to work fine. I can filter data by using both BBOX or e.g. a PropertyIsLike query.
> But...i was now testing the FILTER functions on a layer where the data is from a MS SQL server (point layer). I am fetching my data via OGR. Mapserver renders the layer just fine, i can use WFS BBOX FILTER, but when i try a WMS FILTER using e.g. WFS PropertyIsLike query, Mapserver returns all records in the layer. Nothing gets filtered...
> Should not Mapserver (via WFS) filter data in the same way regardless of how the data is fetched...that is e.g. via SHAPE, POSTGRESQL, OGR etc
> Regards
> Sture
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
