Retrieve a vector layer without a template (flash)
    Eduard Witteveen
    e.witteveen at HAWARIT.COM
    Thu Apr  6 03:17:59 PDT 2006
> Hello list,
> I retrieve a singlelayer flash movie by using the following url:
> ->http://localhost/cgi-bin/mapserv.exe?map=/home/mapserver/flash.map&mode=map
> However, when i want to retrieve a vector layer flash movie, i have to
> retrieve a multi-layer flash movie. This requires me to put define the a
> TEMPLATE, IMAGEPATH and a IMAGEURL.
> Is there noto return single-layer-flash-movies / svg /gml dat a way to
> retrieve a flash vectorlayer the same way as i can retrieve the
> singlelayer(rasterbased)?
Should really be:
Is there not a way to return single-layer-flash-movies / svg /gml, the
same way as i can retrieve the singlelayer(rasterbased)?
Ing. Eduard Yeb Witteveen           Software Engineer
Hawar Information Technology bv   lid Dijkoraad Groep
De Wymerts 7  8701 WT                        Bolsward
Tel: +31 (0)515 570333         Fax: +31 (0)515 570335
http://www.hawarit.com/             nl_NL fy_NL en_US
More information about the MapServer-users
