Bug in Mapserver-4.8.3
Liz Godwin
godwin.liz at GMAIL.COM
Thu Apr 6 09:10:08 EDT 2006
To me it looks like it's triple labelling the same point, just offset
by 1 or 2 pixels each time.
Interesting.
On 4/5/06, Ian Erickson <ierickson at analygis.com> wrote:
> I have a client that has encountered the exact same issues... Although
> they're running a MS4W build including 4.8.1. The attached screen shot
> illustrates the problem. Also, the client states that the problem
> doesn't appear until the font size is set greater than 16.
> Ian Erickson
> AnalyGIS, LLC
> http:// www.analygis.com
> Doyon, Jean-Francois wrote:
> >Well then, I don't know :) We'll have to see if anyone reports any problems
> >I've run into problems with fonts, but they were freetype based issues in
> >the end.
> >I'm running 4.8.1 without problems.
> >J.F.
> >-----Original Message-----
> >From: wbr [mailto:wbr at detemobil.de]
> >Sent: April 5, 2006 1:01 AM
> >To: Doyon, Jean-Francois
> >Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> >Subject: Re: [UMN_MAPSERVER-USERS] Bug in Mapserver-4.8.3
> >Doyon, Jean-Francois schrieb:
> >>Hmmm, and what about GD?
> >>Also, make sure you use "ldd /path/to/executable" to verify things,
> >>don't just rely on which packages you have installed, just in case.
> >>J.F.
> >the gd library is 'gd2-2.0.33'. I only changed the source from mapserver
> >4.6.1 to mapserver 4.8.3 ! After compiling and installing the described
> >Effect takes place.
> >hmmm...
> >Wolfgang Brungert
> >T-Mobile Deutschland GmbH
> >Program and Budget Management
> >(TRPD13-D)
> >Roddestr. 12
> >48153 Münster
> >Phone: +49 251 977 4142
> >Fax: +49 251 977 4149
> >email: wolfgang.brungert at t-mobile.de
> >PGP Fingerprint: B3F8 D368 5EEF 3873 3C4F 423C 171E F217 7CA4 3467
