Bug in Mapserver-4.8.3
Ian Erickson
ierickson at ANALYGIS.COM
Wed Apr 5 19:29:15 EDT 2006
I have a client that has encountered the exact same issues... Although
they're running a MS4W build including 4.8.1. The attached screen shot
illustrates the problem. Also, the client states that the problem
doesn't appear until the font size is set greater than 16.
Ian Erickson
AnalyGIS, LLC
http:// www.analygis.com
Doyon, Jean-Francois wrote:
>Well then, I don't know :) We'll have to see if anyone reports any problems
>I've run into problems with fonts, but they were freetype based issues in
>the end.
>I'm running 4.8.1 without problems.
>J.F.
>-----Original Message-----
>From: wbr [mailto:wbr at detemobil.de]
>Sent: April 5, 2006 1:01 AM
>To: Doyon, Jean-Francois
>Cc: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] Bug in Mapserver-4.8.3
>Doyon, Jean-Francois schrieb:
>>Hmmm, and what about GD?
>>Also, make sure you use "ldd /path/to/executable" to verify things,
>>don't just rely on which packages you have installed, just in case.
>>J.F.
>the gd library is 'gd2-2.0.33'. I only changed the source from mapserver
>4.6.1 to mapserver 4.8.3 ! After compiling and installing the described
>Effect takes place.
>hmmm...
>Wolfgang Brungert
>T-Mobile Deutschland GmbH
>Program and Budget Management
>(TRPD13-D)
>Roddestr. 12
>48153 Münster
>Phone: +49 251 977 4142
>Fax: +49 251 977 4149
>email: wolfgang.brungert at t-mobile.de
>PGP Fingerprint: B3F8 D368 5EEF 3873 3C4F 423C 171E F217 7CA4 3467
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060405/9c6698a4/2006_04_04_144801_257_ms-testcopy.jpg
