copyright text bottomright but mapsize variable
bram
bram at TERNEUZEN.COM
Thu Apr 6 12:49:32 EDT 2006
Bart,
I'm using an extra annotationlayer on top like the example below. It
outputs a small gif and some text in the upperleftcorner independent
from your scale. That your aim, I suppose.
Regards,
Bram
LAYER
NAME "kaartnaam1"
TYPE ANNOTATION
STATUS ON
TRANSFORM false
FEATURE
POINTS 80 80 END
TEXT " testomgeving bestemmingsplannen"
END
CLASS
SYMBOL 'logoterneuzen'
SIZE 100
OUTLINECOLOR 255 0 0
COLOR 255 0 0
TEMPLATE "void"
LABEL
FORCE true
POSITION ur
COLOR 0 0 155
#BACKGROUNDCOLOR 230 230 230
TYPE bitmap
SIZE large
END # label
END #class
END
Huub Fleuren schreef:
> Bart,
> you might want to lay a static (inhome designed) copyright image on top
> of your map. If you 'drag' the image, maybe your client gives you the
> flexibility to let this top image be and just operate on the images
> stacked under it.
> Regards, Huub
> Stephen Woodbridge wrote:
>> See bugs #1547 and #1592 and a gentle prod of the owners would hurt :)
>> -Steve W
>> Bart van den Eijnden wrote:
>>> Hi list,
>>> is it possible to have a copyright layer in the bottom right part of
>>> the
>>> map image, in a situation in which the map size is variable (without
>>> side-effect of the text being in the middle of the map image when the
>>> image size increases :-) )?
>>> Or is it necessary to use Mapscript to change the point coordinates
>>> of the
>>> label in case the map size changes?
>>> Thanks in advance.
>>> Best regards,
>>> Bart
