copyright text bottomright but mapsize variable
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Thu Apr 6 13:01:52 EDT 2006
Hi Bram,
indeed upperleft is the one that will work even with a changing map
size, but most people don't want copyright in the upperleft corner of
the image .... at least some of the customers I have encountered.
I believe Steve has added some additional support for relative
positioning in Mapserver CVS head that will make it possible to put the
copyright in the lowerright corner.
Best regards,
Bart
bram wrote:
> Bart,
> I'm using an extra annotationlayer on top like the example below. It
> outputs a small gif and some text in the upperleftcorner independent
> from your scale. That your aim, I suppose.
> Regards,
> Bram
> LAYER
> NAME "kaartnaam1"
> TYPE ANNOTATION
> STATUS ON TRANSFORM false
> FEATURE
> POINTS 80 80 END
> TEXT " testomgeving bestemmingsplannen"
> END
> CLASS
> SYMBOL 'logoterneuzen'
> SIZE 100
> OUTLINECOLOR 255 0 0
> COLOR 255 0 0
> TEMPLATE "void" LABEL
> FORCE true
> POSITION ur
> COLOR 0 0 155
> #BACKGROUNDCOLOR 230 230 230
> TYPE bitmap
> SIZE large
> END # label
> END #class
> END
> Huub Fleuren schreef:
>> Bart,
>> you might want to lay a static (inhome designed) copyright image on top
>> of your map. If you 'drag' the image, maybe your client gives you the
>> flexibility to let this top image be and just operate on the images
>> stacked under it.
>> Regards, Huub
>> Stephen Woodbridge wrote:
>>> See bugs #1547 and #1592 and a gentle prod of the owners would hurt :)
>>> -Steve W
>>> Bart van den Eijnden wrote:
>>>> Hi list,
>>>> is it possible to have a copyright layer in the bottom right part
>>>> of the
>>>> map image, in a situation in which the map size is variable (without
>>>> side-effect of the text being in the middle of the map image when the
>>>> image size increases :-) )?
>>>> Or is it necessary to use Mapscript to change the point coordinates
>>>> of the
>>>> label in case the map size changes?
>>>> Thanks in advance.
>>>> Best regards,
>>>> Bart
OSGIS, Open Source GIS
http://www.osgis.nl
