clustering points
Heinz-Josef Lücking
h-j.luecking at GGS-BHV.DE
Fri Apr 7 02:50:54 EDT 2006
Is the code of Schuyler available online or do i have to buy that book?
We where thinking about use of K-means for clustering too. Could you
pleae tell me more about the K-means-PostGIS-PostGres thing?
Heinz-Josef Lücking
Fawcett, David schrieb:
> You can see Schuyler's code working at: http://mappinghacks.com/projects/gmaps/cluster.html
> In the Google Maps Hacks book, Schuyler makes a pretty good case for why the tiling approach over K-means for on-the-fly mapping.
> That said, I know of one person doing K-means to cluster points. This is implemented using PostGIS and Postgres-R. Anyone, Bitner?!
> David.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Schuyler Erle
> Sent: Thursday, April 06, 2006 8:01 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] clustering points
> * On 6-Apr-2006 at 2:57AM PDT, Heinz-Josef Lücking said:
>> I?m looking for a solution or hints on clustering points depending on
>> distance. I would like to have just one symbol with diferent sizes
>> depending on how many points are "behind" that symbol.
> I did some experiments with this for Google Maps Hacks, and I found that the fastest way to do this for a map display is to imagine a grid over your map view such that each cell would have the display size of your marker icon. Assign each of your points to the grid cell that contains it. Finally, for each grid cell that contains a point, display a marker on the map for that cell. The marker can vary based on the number of points the cell contains.
> SDE
