clustering points
Jan Hartmann
j.l.h.hartmann at UVA.NL
Mon Apr 10 08:27:24 EDT 2006
See:
http://postgis.refractions.net/pipermail/postgis-users/2006-March/011324.html
Heinz-Josef Lücking wrote:
> Is the code of Schuyler available online or do i have to buy that book?
> We where thinking about use of K-means for clustering too. Could you
> pleae tell me more about the K-means-PostGIS-PostGres thing?
> Heinz-Josef Lücking
> Fawcett, David schrieb:
>> You can see Schuyler's code working at:
>> http://mappinghacks.com/projects/gmaps/cluster.html
>> In the Google Maps Hacks book, Schuyler makes a pretty good case for
>> why the tiling approach over K-means for on-the-fly mapping.
>> That said, I know of one person doing K-means to cluster points. This
>> is implemented using PostGIS and Postgres-R. Anyone, Bitner?!
>> David.
>> -----Original Message-----
>> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
>> On Behalf Of Schuyler Erle
>> Sent: Thursday, April 06, 2006 8:01 AM
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: Re: [UMN_MAPSERVER-USERS] clustering points
>> * On 6-Apr-2006 at 2:57AM PDT, Heinz-Josef Lücking said:
>>> I?m looking for a solution or hints on clustering points depending on
>>> distance. I would like to have just one symbol with diferent sizes
>>> depending on how many points are "behind" that symbol.
>> I did some experiments with this for Google Maps Hacks, and I found
>> that the fastest way to do this for a map display is to imagine a grid
>> over your map view such that each cell would have the display size of
>> your marker icon. Assign each of your points to the grid cell that
>> contains it. Finally, for each grid cell that contains a point,
>> display a marker on the map for that cell. The marker can vary based
>> on the number of points the cell contains.
>> SDE
