java mapscript encoding problem
listuser HH
listuser at HERZSYS.DE
Fri Apr 7 09:02:48 EDT 2006
Hi all,
Oliver Wesp sent a mail some days ago that he has problems with german
umlauts. I'm facing the same problem at the moment when I try to get a
layer by name "Regierungspräsidien". When I use
map.getLayer(0).getName() I get exact the same string - I checked the
bytes. The encoding from the mapscript to java seem to work. I tried to
make a new String with other encoding but I'm not sure which one is the
right but without any luck.These are the bytes I get from the strings:
[82, 101, 103, 105, 101, 114, 117, 110, 103, 115, 112, 114, -28, 115,
105, 100, 105, 101, 110] --> mapscript to java
105, 100, 105, 101, 110] --> ISO8859_1
105, 100, 105, 101, 110] --> CP1252
[82, 101, 103, 105, 101, 114, 117, 110, 103, 115, 112, 114, 63, 115,
105, 100, 105, 101, 110] --> ASCII
105, 100, 105, 101, 110] --> UTF-8
Any ideas how to solve this?
Thanks
Norbert
