Increase Clarity of WMS
Gary Watry
watry at COAPS.FSU.EDU
Mon Apr 10 08:30:04 EDT 2006
My website is
http://gw102.coaps.fsu.edu/httpdocs/indexmaster.html
The layer code for a wms file is
LAYER
NAME Blue_Marble
STATUS OFF
TYPE RASTER
OFFSITE 0 0 0
GROUP "Background"
CONNECTIONTYPE WMS
CONNECTION "http://wms.jpl.nasa.gov/wms.cgi?"
PROJECTION
"init=epsg:4326"
END
METADATA
"wms_name" "modis"
"wms_server_version" "1.1.1"
"wms_srs" "EPSG:4326"
"wms_format" "image/png"
END
END
If you look at it the file is real chunky or blocky, all the wms files work
the same.
Any suggestions?
______________________________________________________________
Gary L. Watry
GIS Coordinator
Center for Ocean-Atmospheric Prediction Studies
FSU / COAPS
Johnson Building, RM 215
2035 East Paul Dirac Drive
Tallahassee, Florida 32306-2840
E-Mail: watry at coaps.fsu.edu
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu] On
Behalf Of Clint Johnson
Sent: Friday, April 07, 2006 7:34 PM
To: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] Increase Clarity of WMS
Kyle,
Your error is due to the line that says
PROCESSING "RESAMPLE=AVERAGE"
If you want a quality image then by all means do NOT use average dithering.
example of average dithering
http://www.visgraf.impa.br/Courses/ip00/proj/Dithering1/average_dithering.ht
ml
Use one of:
PROCESSING "RESAMPLE=BILINEAR"
PROCESSING "RESAMPLE=BICUBIC" # preferable
Stay away from nearest and average.
Without having to go into Digital processing 101, using nearest or
average will cause your image to "chunk" when it is re-sampled (ie
zoomed in or out); whereas, bilinear and bicublic will give it a nice
"anti-aliased" look as you zoom in.
Cheers,
Clint
Clint Johnson
Refractions Research Inc.
Cjohnson at refractions.net
Kyle Mulka wrote:
> Here's one of the WMS tiles I'm using. I've tried stretching it using
> different values for the height and width but nothing I've tried has
> made it look better or worse.
http://kylemulka.com/cgi-bin/mapserv?map=floorplans.map&REQUEST=GetMap&SERVI
CE=WMS&VERSION=1.1.1&LAYERS=dude-1&STYLES=&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE
&SRS=EPSG:4326&BBOX=-83.7158203125,42.2905166207974,-83.71444702148438,42.29
1532494305976&WIDTH=256&HEIGHT=256
> -Kyle
> Josh Livni wrote:
>> Kyle,
>> I could be wrong -- I haven't used a mapserver wms in Google Maps -
>> but I think your mapserver image may be being squashed a bit. It's a
>> bit less wide relative to the height/width of your Imagemagick
>> version. Also the gmap div seems to be a different height/width in
>> the different versions.
>> WMS will happily respond with the exact extent, but perhaps not the
>> relative height/width you expect, thus 'squashing' the image, which
>> may be causing the image issues you're seeing.
>> You may want to play with this by adding a &height &width to the wms
>> query, or you could try playing with the div height/width ratios, and
>> seeing if you get similar results if one is a bit off, as I may be
>> off-base with this theory.
>> -Josh
>> Kyle Mulka wrote:
>>> I have these very detailed floor plans that I'd like to georeference
>>> and display through mapserver's WMS sever, however, the clarity of
>>> the images degrades when it goes through. How can I increase the
>>> clarity of these floorplans through the WMS?
>>> Here's with mapserver:
>>> http://maps.kylemulka.com/floorplan-test10.php
>>> Here's without (simply chopping up tiles using Imagemagick)
>>> http://maps.kylemulka.com/imagemagick/livedude.php
>>> Here's the parts of the map file for just the first floor:
>>> MAP
>>> NAME "UofM"
>>> FONTSET fontset.txt
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> IMAGETYPE png24
>>> EXTENT -83.747063 42.272038 -83.709126 42.297056
>>> SHAPEPATH "/umdata/"
>>> LAYER
>>> NAME "dude-1"
>>> TYPE raster
>>> DATA "dude1.tif"
>>> PROCESSING "DITHER=YES"
>>> METADATA
>>> "wms_title" "dude-1"
>>> "wms_onlineresource"
>>> "http://kylemulka.com/cgi-bin/mapserv?map=floorplans.map&"
>>> END
>>> STATUS ON
>>> END
>>> END
>>> -Kyle
