Increase Clarity of WMS
Jared Chapiewsky
Jpchapiewsky at WISC.EDU
Mon Apr 10 12:11:03 EDT 2006
I had problems with chunky Raster WMSs too, specifically with
TerraServer orthophotos. My solution was to change the format for the
layer to jpeg, like so:
"WMS_FORMAT" "image/jpeg"
and I added one line to my outputformat block for jpeg in the mapfile,
like this:
FORMATOPTION "QUALITY=100"
I'm still serving the final output as png, and there is no chunkiness at
all. I didn't have to mess with any of the PROCESSING options either.
Cheers,
Jared Chapiewsky
Gary Watry wrote:
>My website is
>http://gw102.coaps.fsu.edu/httpdocs/indexmaster.html
>The layer code for a wms file is
>LAYER
> NAME Blue_Marble
> STATUS OFF
> TYPE RASTER
> OFFSITE 0 0 0
> GROUP "Background"
> CONNECTIONTYPE WMS
> CONNECTION "http://wms.jpl.nasa.gov/wms.cgi?"
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> "wms_name" "modis"
> "wms_server_version" "1.1.1"
> "wms_srs" "EPSG:4326"
> "wms_format" "image/png"
> END
>END
>If you look at it the file is real chunky or blocky, all the wms files work
>the same.
>Any suggestions?
>______________________________________________________________
>Gary L. Watry
>GIS Coordinator
>Center for Ocean-Atmospheric Prediction Studies
>FSU / COAPS
>Johnson Building, RM 215
>2035 East Paul Dirac Drive
>Tallahassee, Florida 32306-2840
>E-Mail: watry at coaps.fsu.edu
>-----Original Message-----
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu] On
>Behalf Of Clint Johnson
>Sent: Friday, April 07, 2006 7:34 PM
>To: MAPSERVER-USERS at lists.umn.edu
>Subject: Re: [UMN_MAPSERVER-USERS] Increase Clarity of WMS
>Kyle,
>Your error is due to the line that says
> PROCESSING "RESAMPLE=AVERAGE"
>If you want a quality image then by all means do NOT use average dithering.
>example of average dithering
>http://www.visgraf.impa.br/Courses/ip00/proj/Dithering1/average_dithering.ht
>ml
>Use one of:
>PROCESSING "RESAMPLE=BILINEAR"
>PROCESSING "RESAMPLE=BICUBIC" # preferable
>Stay away from nearest and average.
>Without having to go into Digital processing 101, using nearest or
>average will cause your image to "chunk" when it is re-sampled (ie
>zoomed in or out); whereas, bilinear and bicublic will give it a nice
>"anti-aliased" look as you zoom in.
>Cheers,
>Clint
