Java Mapscript - converting edu.umn.gis.mapscript.imageObj
into a java.awt.image
Benedikt Rothe
umn-ms at HYDROTEC.DE
Mon Apr 10 09:06:49 EDT 2006
Hi James
I think the following post contains the answer:
http://article.gmane.org/gmane.comp.gis.mapserver.user/17904/
The result of the getBytes-method of the imageObj is
javax.imageio.ImageIO.read.
Benedikt
UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU> schrieb am
10.04.2006 13:45:04:
> Hi,
> I am working with java/mapscript and am trying to convert an
> edu.umn.gis.mapscript.imageObj into some kind of java image object
(ideally
> something that implements java.awt.image.RenderedImage ? but anything
would
> be a start). This is so I can manipulate the image, using JAI and
java2d,
> and then stream the modified image as a SOAP message response.
> At the moment I am saving the image to a temporary file (java code shown
> below), using the imageObj.save() method, and then reloading that image
into
> my java object. This is not a desirable solution for obvious
performance
> and scalability reasons ? especially as I seem to need to pause after
the
> save to avoid the load command giving intermittent errors.
> Does anybody have any experience of converting the imageObj into a more
> useful java object? Has anyone written a java or c method to aid this,
or
> found another way round a similar problem?
> Regards,
> James
> ---Java code snippet---
> imageObj image = mapobj.draw(); //define imageObj
> String filename = "/var/www/html/gis/scratch/maptemp.png";
> File filefilename = new File(filename); // set temp file variables
> image.save(filename, mapobj); // save image to disk
> Thread.sleep(1000); // pause to ensure has saved - avoids errors
> BufferedImage bufimg = ImageIO.read(filefilename); // load it again
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060410/f046c5e1/attachment.html
