GetFeatureInfo still not working
Thip
thip at AIT.AC.TH
Tue Apr 11 03:49:55 EDT 2006
Dear Laura and Bart and all,
I think I set everything that you mentioned but when
Case 1: error -- I query through OGC wmsviewer, it comes with: WMS server
error: Invalid layer (S) given in the LAYERS parameter.
Case 2: text/plain return -- If I overlay this layer with maplab and query,
the information given as text/plain not as the template which I set as
table.
When, I follow the WMS server documentation, GETMAP, GETCAPABILITY and
GETFEATUREINFO, the result comes out fine.
So, is there anything that I miss and you figure it out, pls. let me know.
WEB
IMAGEPATH "/data/maplab-2.2/tmp/"
IMAGEURL "/maplab-2.2/tmp/"
METADATA
"wms_title" "INFO" ##required
"wms_feature_info_mime_type" "text/html"
"wms_onlineresource"
"http://203.159.29.10/cgi-bin/mapserv?map=/data/maplab-2.2/AIT/info.map&"
"wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326" ##recommended
"wms_version" "1.1.0"
"wms_getmap"
"wms_getfeatureinfo"
"wms_featureinfoformat" "text/html"
END
END
LAYER
NAME TEST
METADATA
"wms_title" "TEST" ##required
"gml_include_items" "all"
END
TYPE POLYGON
DUMP TRUE
TRANSPARENCY 70
DATA asia_bnd
STATUS ON
CLASSITEM cntry_name
LABELITEM cntry_name
HEADER asia_header.html
FOOTER footer.html
PROJECTION
"init=epsg:4326"
END
CLASS
NAME "Asia Boundary"
EXPRESSION /./
TEMPLATE /data/maplab-2.2/AIT/data/asia.html
STYLE
OUTLINECOLOR 74 74 74
COLOR 192 207 203
END
Thanks in advance,
Thip
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Monday, April 10, 2006 11:02 PM
Subject: Re: [UMN_MAPSERVER-USERS] GetFeatureInfo
> Hi,
> just some points in mapserver documentation:
> 1. ext/html output using MapServer query templates specified in the CLASS
template
> parameter.
> 2. The MIME type returned by the Class templates defaults to text/html and
can be
> controlled using the metadata "wms_feature_info_mime_type"
> 3. Layer TEMPLATE (required for GetFeatureInfo requests)
> 4. Layer DUMP TRUE (only required for GetFeatureInfo GML requests)
> 5. You must set the layer TEMPLATE parameter for the layer to be queryable
by
> GetFeatureInfo requests. For requests of type "text/html" you should also
set the layer
> HEADER and FOOTER parameters. For GetFeatureInfo requests of GML you must
set
> the layer to DUMP TRUE in the mapfile. As of MapServer 4.6 you must also
set the
> gml_* metadata for the layer attributes to be served (see the Layer Object
metadata in
> the Reference Section later in this document).
> an example that works for me:
> LAYER
> NAME obras
> METADATA
> "wms_title" "obras"
> gml_include_items "all"
> END
> STATUS ON
> TYPE POLYGON
> DUMP TRUE
> PROJECTION
> "init=epsg:23030"
> END
> CONNECTIONTYPE postgis
> CONNECTION
> TOLERANCE 3
> CLASS
> NAME "obras"
> TEMPLATE 'gmap/htdocs/templates/popplace.html'
> COLOR 0 240 240
> OUTLINECOLOR 199 199 199
> END
> END
> regards,
> Larua
> On 10 Apr 2006 at 21:27, SUBSCRIBE MAPSERVER-USERS Joe wrote:
> > Dear all,
> > I set up my server as WMS Server. The problem is I could not query as
html which
> > I provide template, header and footer file.
> > Is there anyone has an experience setting up WMS server for
getfeatureinfo?
> > I set up my map file as
> > WEB
> > METADATA
> > "http://server.com/cgi-bin/mapserv?map=/data/maplab-2.2/AIT/info.map&"
##recommended
> > END
> > LAYER
> > NAME TEST
> > METADATA
> > "wms_extent" "92.189278,5.610009,109.464638,29.180666"
> > END
> > TYPE POLYGON
> > TRANSPARENCY 70
> > DATA asia_bnd
> > STATUS ON
> > TEMPLATE asia.html
> > END
> > Thanks in advance,
> > Thip
> > This mail sent through AIT WebMail : http://www.ait.ac.th/
