Wrapping map extents
Frank Warmerdam
warmerdam at POBOX.COM
Tue Apr 11 06:36:16 PDT 2006
Neil Saunders wrote:
> Hello all,
> Could somebody offer some advice regarding mercator projections.. the
> problem I have is the projection of the globe. The far east of Russia
> and the far west of America both 'wrap around' to the other side of
> the globe, which is causing me problems in the way I'm trying to
> visualise things. Looking at Google Maps, they seem to have altered
> the east and west extents of the map to allow for these (and the
> Oceania islands). I was hoping I might achieve the same thing. Is
> there some way of altering the projection to do this? I've seen this
> on standard atlases before so I'm assuming its a fairly common thing
> but I can't find anything on the web about it in mapserver.
> Thanks for reading and any help you have,
Neil,
There are quite a few factors that come into play. What types of input
data (raster? vector?) are you using? What projections is it in?
If you want a wrap around world with some areas represented twice on the
map image, and the source data is vector it just isn't going to work unless
the source data is already in mercator and already "doubled up".
The raster reprojector on the other hand can take a single world image and
apply it in multiple places because raster reprojection is mostly done
by back-projection. That is, take a location on the map, reproject it to
the source projection and sample the raster. So it is ok for multiple
parts of the output map to sample from the same input location.
I have attached a sample map in mercator with wrap around and vector and
raster layers (all in geographic). Note that the raster layers wrap, but
the vector layers don't. That map file looks like:
MAP
NAME 'ORTH_TEST'
IMAGETYPE JPEG
EXTENT -30000000 -15000000 14000000 15000000
SIZE 600 300
PROJECTION
"+proj=merc +datum=WGS84"
END
LAYER
NAME "bm"
TYPE RASTER
STATUS DEFAULT
DATA "/home/warmerda/public_html/world.tif"
PROCESSING "LOAD_WHOLE_IMAGE=YES"
PROJECTION
"+proj=latlong +datum=WGS84"
END
END
LAYER
NAME "world"
TYPE LINE
STATUS DEFAULT
DATA "world.shp"
PROJECTION
END
CLASS
OUTLINECOLOR 255 0 0
COLOR 0 255 0
END
END
END
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060411/68c42e2d/attachment.jpg>
More information about the MapServer-users
