Colors for features
john
jwpaige at PACBELL.NET
Tue Apr 11 15:26:20 EDT 2006
I am now able to produce maps using shp2img.
The map file file below produces all lines as green. What do I need
to change to
show features in different colors. I had thought this would produce
red, green, and blue
features depending on the expression. Also, I have had no luck in
showing lakes, streams, etc.
All files incuding the TGR and font files are in /usr/testfiles
Thanks for any help to keep going
MAP
SIZE 600 600
EXTENT -156.682 20.870 -156.675 20.8770
FONTSET "/usr/testfiles/Fontset.txt"
LAYER # Start of LAYER object
NAME CompleteChain
TYPE LINE
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "/usr/testfiles"
LABELITEM "FENAME"
CLASS # Start of CLASS object
COLOR 0 200 0
LABEL
TYPE TRUETYPE
FONT sans-bold
BUFFER 7
MINFEATURESIZE 0
MINDISTANCE 350
POSITION CC
ANGLE AUTO
SIZE 7
COLOR 70 70 70
PARTIALS false
OUTLINECOLOR 255 255 255
END
END
CLASSITEM 'CFCC'
CLASS
NAME "City Streets"
EXPRESSION /A4/
COLOR 200 0 0
END # End of CLASS object
CLASS
NAME "Other Streets"
EXPRESSION /A[1-3]/
COLOR 0 200 0
CLASS
NAME "Some Streets"
EXPRESSION /A[5-9]/
COLOR 0 0 200
END # End of LAYER object
END
