Mysql
Howard Butler
hobu at IASTATE.EDU
Wed Apr 12 09:17:09 EDT 2006
Grabiel,
It appears as though there are spaces in between the parameters of
your MySQL connection string. I think it should be:
MySQL:test,host=hostname.somewhere,user=root,password=pw
I'm not sure this is the real issue though,
Howard
At 8:29 AM -0400 4/12/06, grabiel wrote:
>Hi
> Thats excellent in a very short period of time (What time).
> I am using gdal 1.5 but when i try to execute ogrinfo 'MYSQL:test,
>host=localhost, user=root, password=mypass, tables=asmroad1' asmroad1
> from command line it gives result like this-------->
> >ogrinfo 'MYSQL:test, host=localhost.localdomain, user=root,
>password=zxcvydas, tables=asmroad1' asmroad1
> >Warning 1: ' host=localhost.localdomain' in MYSQL datasource
>definition not recognised and ignored.
> >Warning 1: ' user=root' in MYSQL datasource definition not
> >Warning 1: ' password=zxcvydas' in MYSQL datasource definition not
> >Warning 1: ' tables=asmroad1' in MYSQL datasource definition not
> >INFO: Open of `MYSQL:test, host=localhost.localdomain, user=root,
> >using driver `MySQL' successful.
> >Layer name: asmroad1
> >Geometry: None
> >Feature Count: 5
> >Layer SRS WKT:
> >(unknown)
> >road_name: String (0.0)
> >road_id: Integer (0.0)
> >roadtype: String (0.0)
> >OGRFeature(asmroad1):0
> >road_name (String) = NH51
> >road_id (Integer) = 4
> >roadtype (String) = metallic
> >OGRFeature(asmroad1):1
> >road_name (String) = NH39
> >road_id (Integer) = 3
> >roadtype (String) = NonMetallic
> >OGRFeature(asmroad1):2
> >road_name (String) = NH54
> >road_id (Integer) = 2
> >roadtype (String) = Mettalic
> >OGRFeature(asmroad1):3
> >road_name (String) = NH53
> >road_id (Integer) = 1
> >roadtype (String) = Metallic
>>OGRFeature(asmroad1):4
> >road_name (String) = NH42
> >road_id (Integer) = 5
> >roadtype (String) = Semimetallic
> All the datas and fields are showing in the output. But after
>modifying my mapfile when i access the page, it gives an error "The
>documents contain no data".
> Now with documented map file is like this->
> LAYER
> NAME "asmroad"
> TYPE LINE
> CONNECTIONTYPE ogr
> CONNECTION "asmroad.shp" /*This is the shape file in my data ditectory*/
> /* I am trying to connect route_na field in my asmroad.dbf
>which is in data directory */
> /* to the field name road_name in asmroad1 table in mysql */
> /* So i have written my code like this */
> DATA "SELECT * FROM asmroad1 LEFT JOIN
>'MYSQL:test,host=localhost, user=root,
> password=mypass'.road_name ON asmroad1.road_name = route_na.roadjoin1"
> STATUS ON
>END
> Whether the code above is correct? Maybe a little bit of correction is
> needed in the DATA part. I have used a unique name for a connection
>by the name "roadjoin1". You can refer it to my previous mail. But
>What is it doing here just before the line STATUS ON in my map file.
>I think since you decipher the text, so u will know its uses here.
>Thanks
>Grabiel
> --- On Tue 04/11, William Kyngesburye < woklist at kyngchaos.com > wrote:
>From: William Kyngesburye [mailto: woklist at kyngchaos.com]
>To: mapserver-users at lists.umn.edu
> Cc: grabiel at MYWAY.COM
>Date: Tue, 11 Apr 2006 09:10:24 -0500
>Subject: Re: Mysql
>After digging around the list archives and dealing with software
>updates and bugs, I finally figured this out yesterday (what
>timing!). The main key is that you use GDAL, not MapServer directly
>or ODBC.What you need then, is GDAL 1.3.1 with MySQL table support.
>MapServer version shouldn't matter. There are a couple sticky
>problems, tho. One is that GDAL automatically detects a feature ID
>field in the database and doesn't include it in the field list for
>the table. I don't know the particulars for how it decides it a
>field is an 'FID', but it's something like, integer field as a
>primary key. You should be OK with string fields.You can check what
>OGR sees by duplicating the MySQL connection string aprt from below
>(without the .table part, but with tables=) with ogrinfo on the
>commandline:ogrinfo -al -so
>'MYSQL:database,host=whatever,user=whatever,password=whatever,tables=you
>rtable'Another problem is that GDAL curently doesn't detect tinyints
>or smallints
>(thinks they're strings), so if those are used for your relate
>field, it may not work.Now for the MAP file stuff:CONNECTIONTYPE
>ogrCONNECTION "asmroad.shp"DATA "SELECT * FROM asmroad LEFT JOIN
>'MYSQL:test,host=localhost,user=username,password=userpass'.route_na
>ON asmroad.road_name = route_na.roadjoin1"Assuming I'm deciphering
>the connection/join statements right, they don't seem to be
>documented yet. You don't need the JOIN block.Basically,
>CONNECTIONTYPE will always be OGR. CONNECTION can be one of 2
>things: either the full relative path to the shapefile as it would
>be in a DATA statement + .shp, it must include the full file name,
>unlike in DATA statements; or if the shapefile is in subfolder you
>can list just the subfolder, because of the way OGR handles
>datasources and layers, but it can't be empty (CONNECTION "").The
>OGR mysql connection string format (see also the OGR documentation
>for the MySQL format) is
>'MYSQL:database,host=,user=,password=,tables='.table. Host defaults
>to localhost, password can be left out if there is none. Tables
>(inside the quote) is a semicolon-seprated list of tables to
>restrict the search to (can speed things up when there are many
>tables), and table (after the dot) is the table you want.The join
>part, ON shapedbf.joinfield1 = mysqltable.joinfield2 should be easy
>to figure out.Be aware that I only tried this so far on joining by
>integer fields. Haven't tried string fields yet.On Apr 11, 2006,
>at 5:08 AM, grabiel wrote:>>>> Hi> I am trying to connect Mysql
>table for non spatial data. But in > the final output in the
>browser all the fields from the .DBF files > are shown, no data
>from mysql table are added. I also manipulated > the To and FROM
>field in the map file but its all the same. If i > change the
>table name in the mapfile the result is same. I > guess its not
>working at all.>> My mapfile is something like>>
>...................> LAYER> NAME "asmroad"> TYPE LINE>
>STATUS Off> DATA "asmroad"> CLASS>> NAME "Road">
>TEMPLATE "road.html" > COLOR 200 50 100> END>>
>HEADER "road_header.html"> FOOTER "road_footer.html">>
>JOIN> CONNECTIONTYPE mysql> CONNECTION
>"localhost:mysql:zxmnt:test"> TABLE "amroad"> TO
>"route_na"> NAME "roadjoin1"> FROM "road_name">
>END> END>> I am using the PHP/mapscript. Whether any DSN should
>be created > for these type of data access?> Hoping to get
>suggestion from the list members.> Thanks>> Grabri>>>>
>_______________________________________________> No banners. No
>pop-ups. No kidding.> Make My Way your home on the Web -
>http://www.myway.com-----William Kyngesburye
><kyngchaos at kyngchaos.com>http://www.kyngchaos.com/"Oh, look, I seem
>to have fallen down a deep, dark hole. Now what does that remind
>me of? Ah, yes - life."- Marvin
>No banners. No pop-ups. No kidding.
>Make My Way your home on the Web - http://www.myway.com
