Mysql
William Kyngesburye
woklist at KYNGCHAOS.COM
Wed Apr 12 12:15:11 EDT 2006
As Howard mentioned, those spaces in the mysql string. I tried the
one I worked on to figure this out - when I added spaces like yours,
failure.
Also, by 'gdal 1.5', do you mean 1.2.5? I'm guessing the MySQL
support in in your build of GDAL, since it's complaining about the
options in the string, not MySQL support missing. 1.2.5 should be
good enough for basic mysql table access, but there have been a few
fixes since then for recognizing some field types (some number fields
might show up as strings).
On Apr 12, 2006, at 7:29 AM, grabiel wrote:
> Hi
> Thats excellent in a very short period of time (What time).
> I am using gdal 1.5 but when i try to execute ogrinfo
> 'MYSQL:test, host=localhost, user=root, password=mypass,
> tables=asmroad1' asmroad1
> from command line it gives result like this-------->
>> ogrinfo 'MYSQL:test, host=localhost.localdomain, user=root,
>> password=zxcvydas, tables=asmroad1' asmroad1
>> Warning 1: ' host=localhost.localdomain' in MYSQL datasource
>> definition not recognised and ignored.
>> Warning 1: ' user=root' in MYSQL datasource definition not
>> Warning 1: ' password=zxcvydas' in MYSQL datasource definition not
>> Warning 1: ' tables=asmroad1' in MYSQL datasource definition not
>> INFO: Open of `MYSQL:test, host=localhost.localdomain, user=root,
>> using driver `MySQL' successful.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that
the past isn't a fiction designed to account for the discrepancy
between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
