On the fly RASTER warping
Michael S. Birkmose
msb at GATEHOUSE.DK
Wed Apr 12 10:40:19 EDT 2006
> Hello,
> If your EXTENT are degrees (-180 -90 180 90), so your UNITS should be
DD
> and not METERS and this should match your map projection setting.
> And if your wms server is Danmark only, try focusing on Danmark, not
the
> world!
> Didn't found any epsg:54004, is it standard ?
> Marc Monnerat
Hi Marc
Your input helped me further - now I can actually generate the map with
the 54004 (Mercator) projection).
However I have a bit of a problem.
In my PHP mapscript I can only display something by using the
coordinates in meters as you supplied it:
$gpoMap = ms_newMapObj("wmsmmap.map");
$gpoMap->setExtent(868292.03, 7135562.57, 1447153.38, 7931049.58);
However I would like to set the extent using degrees - i.e:
$gpoMap->setExtent(7.8, 54, 13, 58);
How would I do this?
Alternativly how could I convert my degrees to meters as you supplied
it?
Best regards,
Michael
