phpmapscript
Murat Beyhan
beyhan at DEPREM.GOV.TR
Thu Apr 13 08:49:53 EDT 2006
Dear Friends,
I have problem for using phpmapscript.
I'm using Mandrake 10.2 and I have downloaded and installed php4.4.2 and
mapserver4.8.3.
actually Apache server which I'm using 2.0.53 version comes php as modules
version is 4.3.10.
I have installed PHP4.4.2 on /usr/bin/php-4.4.2/ directory succesfully and
I have installed Mapserver /usr/bin/mapserver-4.8.3/ by using following
command succesfully
./configure --with-php=/usr/bin/php-4.4.2/
make
cp mapserv /var/www/cgi-bin
than after this
I have copied php_mapscript.so file which is existing under directory of
"/usr/bin/mapserver-4.8.3/mapscript/php3/"
by using following command to directory ../extensions
cp php_mapscript.so /usr/lib/php/extensions/
Than When I try to open phpinfo_mapscript.phtml file attached file opening and
php_mapscript seems installed but I'm not sure this way is correct.
MapScript
MapServer Version MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=SVG SUPPORTS=FREETYPE INPUT=EPPL7 INPUT=JPEG
INPUT=SHAPEFILE
PHP MapScript Version ($Revision: 1.242.2.2 $ $Date: 2006/03/16 21:03:01 $)
But when I'm trying to test gmap75.phtml
I'm facing following error mesages
Warning: dl(): Unable to load dynamic library
'/usr/lib/php/extensions/php_dbase.so'
- /usr/lib/php/extensions/php_dbase.so: cannot open shared object file: No
such file or directory in /var/www/html/gmap-ms46/htdocs/gmap75.phtml on line
58
and
Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
'bathymetry'. in /var/www/html/gmap-ms46/htdocs/gmap75.inc.php on line 550
Warning: [MapServer Error]: drawTIFF(): TIFF support is not available.
Fatal error: Call to a member function on a non-object
in /var/www/html/gmap-ms46/htdocs/gmap75.inc.php on line 552
So How can I run mapserver with phpmapscript applications...
Please ıf anyone will help me I will be thankfull to him/her...
Thank you for your interest...
Murat BEYHAN
Geophysical Engineer, M.Sc
Earthquake Research Department
Ankara/TURKEY
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060413/9b2d910c/phpinfo_mapscript_002.gif
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060413/9b2d910c/phpinfo_mapscript.gif
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060413/9b2d910c/phpinfo_mapscript.html
