User-Agent in WMS client
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Thu Apr 13 10:23:04 EDT 2006
Hi list,
the WMS client code of Mapserver does not set the User-Agent in the http
headers, and we have encountered some Apache webservers which throw an
internal server error when there is no User-Agent set. We have successfully
patched our maphttp.c with the change below and this seems to work. Would it
be a good idea to apply this patch (or a similar patch) in Mapserver's
source code?
/* set URL, note that curl keeps only a ref to our string buffer */
curl_easy_setopt(http_handle, CURLOPT_URL, pasReqInfo[i].pszGetUrl
// patch
char szBuf[100];
struct curl_slist *headers=NULL;
snprintf(szBuf, 100, "User-Agent: curl");
headers = curl_slist_append(headers, szBuf);
curl_easy_setopt(http_handle, CURLOPT_HTTPHEADER, headers);
// end patch
Best regards,
Bart
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
