connection to esri geodatabase
Khaled Kamoun
khaled.kamoun at GMAIL.COM
Mon Apr 17 03:45:55 EDT 2006
I have recived this error when i tried to open the geodatabase with ogrinfo
FAILURE:
Unable to open datasource
`C:\Inetpub\wwwroot\MapservApp\donnee\021_La_Goulette_
SO.mdb' with the following drivers.
-> ESRI Shapefile
-> UK .NTF
-> SDTS
-> TIGER
-> S57
-> MapInfo File
-> DGN
-> VRT
-> AVCBin
-> REC
-> Memory
-> CSV
-> GML
-> ODBC
-> PostgreSQL
What can I do now?
2006/4/15, Steve Pashby <s.pashby at postgrad.curtin.edu.au>:
> Khaled Kamoun <khaled.kamoun <at> GMAIL.COM> writes:
> > Hello,
> > I want to connect to an ESRI geodatabase named "021_La_Goulette_SO.mdb"
> and
> use a layer named "RCROUCAL"
> > I used this code:
> > CONNECTIONTYPE
> ogrCONNECTION
> "C:\Inetpub\wwwroot\MapservApp\donnee\021_La_Goulette_SO.mdb"DATA
> "RCROUCAL"
> > but i recived this error :
> > msDrawMap(): Image handling error. Failed to draw layer named
> 'Rcroucal'.
> msOGRFileOpen(): OGR error. Open failed for OGR connection
> `C:\Inetpub\wwwroot\MapservApp\donnee\021_La_Goulette_SO.mdb'. File not
> found
> or unsupported format.
> > How can I do;
> > Thank you
> > -- Khaled KAMOUN
> Hi Khaled,
> I've just recently connected to an ESRI geodatabase - and had some
> problems to
> start with too.
> Try running 'ogrinfo' from the Command Line Promt and see if it can access
> your data, ie->
> ogrinfo C:\Inetpub\wwwroot\MapservApp\donnee\021_La_Goulette_SO.mdb
> -summary
> and see if you get a summary of your data. If you can, at least you know
> MapServer CAN access your data.
> See what happens ...
> Cheers,
> Steve
Khaled KAMOUN
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060417/4665710c/attachment.html
