connection to esri geodatabase {Scanned}
Khaled Kamoun
khaled.kamoun at GMAIL.COM
Mon Apr 17 12:09:09 EDT 2006
thank you,
My gdal version is 1.2.6
2006/4/17, Siki Zoltan <siki at agt.bme.hu>:
> Dear Khaled,
> Start any of the gdal utilities (gdalinfo, gdal_translate, ...) with a
> switch --version
> for example
> gdalinfo --version
> Probably you have both 1.2 and 1.3 on your matchine.
> Zoltan
> On Mon, 17 Apr 2006, Khaled Kamoun wrote:
> > dear Zoltan,
> > how can i know which version of gdal i'm using?
> > i have 2 dll file gdal12.dll and gdal13.dll
> > thank you
> > > Dear Khaled,
> > > Which version of gdal are you using?
> > > ESRI Personal Geobase is supported (AFAIK) 1.3.x
> > > Zoltan
> > > > I have recived this error when i tried to open the geodatabase with
> > > ogrinfo
> > > > FAILURE:
> > > > Unable to open datasource
> > > > `C:\Inetpub\wwwroot\MapservApp\donnee\021_La_Goulette_
> > > > SO.mdb' with the following drivers.
> > > > -> ESRI Shapefile
> > > > -> UK .NTF
> > > > -> SDTS
> > > > -> TIGER
> > > > -> S57
> > > > -> MapInfo File
> > > > -> DGN
> > > > -> VRT
> > > > -> AVCBin
> > > > -> REC
> > > > -> Memory
> > > > -> CSV
> > > > -> GML
> > > > -> ODBC
> > > > -> PostgreSQL
> > > > What can I do now?
> > > > 2006/4/15, Steve Pashby <s.pashby at postgrad.curtin.edu.au>:
> > > > > Khaled Kamoun <khaled.kamoun <at> GMAIL.COM> writes:
> > > > > > Hello,
> > > > > > I want to connect to an ESRI geodatabase named
> > > "021_La_Goulette_SO.mdb"
> > > > > and
> > > > > use a layer named "RCROUCAL"
> > > > > > I used this code:
> > > > > > CONNECTIONTYPE
> > > > > ogrCONNECTION
> > > > > "C:\Inetpub\wwwroot\MapservApp\donnee\021_La_Goulette_SO.mdb"DATA
> > > > > "RCROUCAL"
> > > > > > but i recived this error :
> > > > > > msDrawMap(): Image handling error. Failed to draw layer named
> > > > > 'Rcroucal'.
> > > > > msOGRFileOpen(): OGR error. Open failed for OGR connection
> > > > > `C:\Inetpub\wwwroot\MapservApp\donnee\021_La_Goulette_SO.mdb'.
> File
> > > not
> > > > > found
> > > > > or unsupported format.
> > > > > > How can I do;
> > > > > > Thank you
> > > > > > -- Khaled KAMOUN
> > > > > Hi Khaled,
> > > > > I've just recently connected to an ESRI geodatabase - and had some
> > > > > problems to
> > > > > start with too.
> > > > > Try running 'ogrinfo' from the Command Line Promt and see if it
> can
> > > access
> > > > > your data, ie->
> > > > > ogrinfo
> > > > > -summary
> > > > > and see if you get a summary of your data. If you can, at least
> you
> > > know
> > > > > MapServer CAN access your data.
> > > > > See what happens ...
> > > > > Cheers,
> > > > > Steve
> > > > Khaled KAMOUN
> > Khaled KAMOUN
Khaled KAMOUN
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060417/8d37aee0/attachment.html
