connection to esri geodatabase {Scanned}
Khaled Kamoun
khaled.kamoun at GMAIL.COM
Mon Apr 17 07:45:44 PDT 2006
dear Zoltan,
how can i know which version of gdal i'm using?
i have 2 dll file gdal12.dll and gdal13.dll
thank you
2006/4/17, Siki Zoltan <siki at agt.bme.hu>:
> Dear Khaled,
> Which version of gdal are you using?
> ESRI Personal Geobase is supported (AFAIK) 1.3.x
> Zoltan
> On Mon, 17 Apr 2006, Khaled Kamoun wrote:
> > I have recived this error when i tried to open the geodatabase with
> ogrinfo
> > FAILURE:
> > Unable to open datasource
> > `C:\Inetpub\wwwroot\MapservApp\donnee\021_La_Goulette_
> > SO.mdb' with the following drivers.
> > -> ESRI Shapefile
> > -> UK .NTF
> > -> SDTS
> > -> TIGER
> > -> S57
> > -> MapInfo File
> > -> DGN
> > -> VRT
> > -> AVCBin
> > -> REC
> > -> Memory
> > -> CSV
> > -> GML
> > -> ODBC
> > -> PostgreSQL
> > What can I do now?
> > 2006/4/15, Steve Pashby <s.pashby at postgrad.curtin.edu.au>:
> > > Khaled Kamoun <khaled.kamoun <at> GMAIL.COM> writes:
> > > > Hello,
> > > > I want to connect to an ESRI geodatabase named
> "021_La_Goulette_SO.mdb"
> > > and
> > > use a layer named "RCROUCAL"
> > > > I used this code:
> > > > CONNECTIONTYPE
> > > ogrCONNECTION
> > > "C:\Inetpub\wwwroot\MapservApp\donnee\021_La_Goulette_SO.mdb"DATA
> > > "RCROUCAL"
> > > > but i recived this error :
> > > > msDrawMap(): Image handling error. Failed to draw layer named
> > > 'Rcroucal'.
> > > msOGRFileOpen(): OGR error. Open failed for OGR connection
> > > `C:\Inetpub\wwwroot\MapservApp\donnee\021_La_Goulette_SO.mdb'. File
> not
> > > found
> > > or unsupported format.
> > > > How can I do;
> > > > Thank you
> > > > -- Khaled KAMOUN
> > > Hi Khaled,
> > > I've just recently connected to an ESRI geodatabase - and had some
> > > problems to
> > > start with too.
> > > Try running 'ogrinfo' from the Command Line Promt and see if it can
> access
> > > your data, ie->
> > > ogrinfo C:\Inetpub\wwwroot\MapservApp\donnee\021_La_Goulette_SO.mdb
> > > -summary
> > > and see if you get a summary of your data. If you can, at least you
> know
> > > MapServer CAN access your data.
> > > See what happens ...
> > > Cheers,
> > > Steve
> > Khaled KAMOUN
Khaled KAMOUN
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060417/beee3eec/attachment.htm>
More information about the MapServer-users
