connection to esri geodatabase {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Mon Apr 17 13:39:12 EDT 2006
Dear Khaled,
Which version of gdal are you using?
ESRI Personal Geobase is supported (AFAIK) 1.3.x
Zoltan
On Mon, 17 Apr 2006, Khaled Kamoun wrote:
> I have recived this error when i tried to open the geodatabase with ogrinfo
> FAILURE:
> Unable to open datasource
> `C:\Inetpub\wwwroot\MapservApp\donnee\021_La_Goulette_
> SO.mdb' with the following drivers.
> -> ESRI Shapefile
> -> UK .NTF
> -> SDTS
> -> TIGER
> -> S57
> -> MapInfo File
> -> DGN
> -> VRT
> -> AVCBin
> -> REC
> -> Memory
> -> CSV
> -> GML
> -> ODBC
> -> PostgreSQL
> What can I do now?
> 2006/4/15, Steve Pashby <s.pashby at postgrad.curtin.edu.au>:
> > Khaled Kamoun <khaled.kamoun <at> GMAIL.COM> writes:
> > > Hello,
> > > I want to connect to an ESRI geodatabase named "021_La_Goulette_SO.mdb"
> > and
> > use a layer named "RCROUCAL"
> > > I used this code:
> > > CONNECTIONTYPE
> > ogrCONNECTION
> > "C:\Inetpub\wwwroot\MapservApp\donnee\021_La_Goulette_SO.mdb"DATA
> > "RCROUCAL"
> > > but i recived this error :
> > > msDrawMap(): Image handling error. Failed to draw layer named
> > 'Rcroucal'.
> > msOGRFileOpen(): OGR error. Open failed for OGR connection
> > `C:\Inetpub\wwwroot\MapservApp\donnee\021_La_Goulette_SO.mdb'. File not
> > found
> > or unsupported format.
> > > How can I do;
> > > Thank you
> > > -- Khaled KAMOUN
> > Hi Khaled,
> > I've just recently connected to an ESRI geodatabase - and had some
> > problems to
> > start with too.
> > Try running 'ogrinfo' from the Command Line Promt and see if it can access
> > your data, ie->
> > ogrinfo C:\Inetpub\wwwroot\MapservApp\donnee\021_La_Goulette_SO.mdb
> > -summary
> > and see if you get a summary of your data. If you can, at least you know
> > MapServer CAN access your data.
> > See what happens ...
> > Cheers,
> > Steve
> Khaled KAMOUN
